Toyota 7FGU45:
Toyota with GM 4.3L Vortec - crank bolt
Anybody have had problems with the Front crank bolt coming loose or breaking off? All items were replaced and is still happening.
  • Posted 1 Nov 2015 05:50
  • Discussion started by swabal
I had this issue before, check and make sure your engine mounts are not broken or severely worn.
  • Posted 7 Nov 2015 14:16
  • Reply by fixnproblems
Ray, the engine starts and runs fine. The pulley has been spinning on the balancer. The mating surfaces between the balancer and pulley are not completely flat. Im not sure if the mating surface problem is the cause or effect at this point since I inherited the truck from someone else. I am sure that it is what has caused the bolt to back off and break though.
  • Posted 6 Nov 2015 00:24
  • Reply by swabal
Is the balancer spinning on the crank causing no start?
  • Posted 2 Nov 2015 04:44
  • Reply by EasiTek
Kalmar DCG16-900
Terberg YT182
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
