Toyota Elec Forklift will not lift
Model Number is 5FBE15. I can hear the board click when I engage the lift, but nothing moves. Lift, tilt, and side shift are all in-op. P/S is hard as well, but is improving.
No other problems.
  • Posted 30 Sep 2009 02:34
  • Discussion started by sra4031
  • Tennessee, United States
The only solution is to change the parameter of the pump with the function from the display
  • Posted 25 Oct 2009 07:56
  • Reply by franco_c
  • Bologna, Italy
Sorry, thought I updated this.
Lift problem was stuck brushes.
P/S was computer reset.
  • Posted 9 Oct 2009 01:07
  • Reply by sra4031
If your contactor is coming in it maybe your hydraulic motor or cables going to the motor or problem with the contactor it self Thanks Rich
  • Posted 8 Oct 2009 07:13
  • Reply by rich_k
Found out my data tag is wrong, it is a 5FBC from Rick.
  • Posted 1 Oct 2009 02:02
  • Reply by sra4031
edit.
  • Posted 30 Sep 2009 23:21
  • Modified 9 Jan 2010 09:48 by poster
  • Reply by rick_c
Where is the fuse I need to check?
  • Posted 30 Sep 2009 22:49
  • Reply by sra4031
jason at turf-aire dot com
Thanks
  • Posted 30 Sep 2009 13:02
  • Reply by sra4031
edit
  • Posted 30 Sep 2009 12:11
  • Modified 9 Jan 2010 09:47 by poster
  • Reply by rick_c
OK, we took another look at it, and next to the power steering pump where the 75 AMP is there is a button you can push in to activate the power steering pump. When we push that in the pumps kicks on and it freely steers, but once released the pump stops working.
  • Posted 30 Sep 2009 05:52
  • Reply by sra4031
Know you might be busy Rick, and I appreciate the help, but did you come up with anything?
  • Posted 30 Sep 2009 05:10
  • Reply by sra4031
I do not get any error codes when I turn the unit on, steer, or try to lift. Is there a special way to pull error codes off. I have seen E3 several time, but assume that is the deadman swith error.
  • Posted 30 Sep 2009 03:45
  • Reply by sra4031
serial # is 11184
No I do not hear the power steering energize, but I do not think I ever heard any noise when I turned.
When I try to use the lift all I get is the clicking. When it started going out it was quick. First it lift very slowly, and then stopped working.
  • Posted 30 Sep 2009 03:43
  • Reply by sra4031
edit
  • Posted 30 Sep 2009 03:32
  • Reply by rick_c
KION reports dip in Q1 revenue Frankfurt am Main, Germany
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
