Toyota 7HBW23 Code C14
Have this unit with a code C14, have lift/lower and horn, any ideas out there?
  • Posted 10 Oct 2012 04:41
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
THANK YOU SOOO MUCH. It was the limit switch in the angle sensor. Awesome advice!!!
  • Posted 27 Oct 2012 10:51
  • By 1sharpdog
David Sharp
Awesome, thanks for the help. Will let you know how it went!!
  • Posted 13 Oct 2012 10:33
  • By 1sharpdog
David Sharp
Also check the the small gray wires......have found bad wiring on a couple.
  • Posted 11 Oct 2012 07:25
  • By Prentice
Check the angle arm switches. Pull the cover at the bottom of the the handle and the switches are there.
  • Posted 10 Oct 2012 06:24
  • By rogeriwt
Muncie, IN, United States
