Toyota 7FGU35 camshaft sensor location
Hello all,
I have purchased this sensor and cannot locate it on the 4.3 GM engine. It is NOT on the timing chain cover. Any help appreciated!! Thanks
SN:63108
  • Posted 25 May 2013 02:13
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
if your trying to measure that signal with a volt meter you probably wont get a definitive reading. It pulses so fast your meter probably doesnt pick it up.
You'll need the diagnostic software to monitor whats going on in the ignition system, it has a graph readout along with digital readings that show that.
Of course there could also be a problem with the pickup sensor on the reluctor wheel.
just a thought
  • Posted 26 May 2013 13:52
Hmmmm..
I am getting a very low voltage out of the purple/orange wire when spinning over (CMP -), but nothing at the grey/ brown (CMP+) wire.
Problem is no/ weak ignition fire and I am thinking the CMP- wire should pulse. Any ideas??
  • Posted 25 May 2013 08:37
  • By Forkliftt
Steve
THANK YOU!!
  • Posted 25 May 2013 04:09
  • By Forkliftt
Steve
check inside the distributor cap ;o)
  • Posted 25 May 2013 03:36
Deborah Baker Deborah Baker
Muncie, IN, United States
