Toyota 7FBR18 steering problem
Hi, Everyone,
I am having a problem with a Toyota 7FBR18 Serial number 7FBR18-10233. I have changed the encoder located at the wheel and I do know if it is need to be calibrated, there is also, a black rounded device it looks like a sensor(not sure). the problem is that at the time I want to turn to the right the speed is going down and it start "jumping" and a TCR alarm is showed on the dispaly. I have been trying to calibrate it but I got a different alarm code 71-R.
Can somebody help me to find out the root cause of this problem?
Thank you - Luis
  • Posted 22 May 2007 13:29
  • By luis_v
  • joined 25 Feb'07 - 127 messages
  • Mexico
the tps like sensor switch was bad figured it out. Shame I didn't know what TPS that is Toyota got me for 380$ I am sure that is a tps you could probably get for $60
  • Posted 14 Jan 2011 23:22
  • By Dave T
  • joined 6 Nov'10 - 34 messages
  • New Jersey, United States
I am having a similar problem on a f7beu15 i changed the steering rack it was leaking and can't seem to get the darn thing calibrated with the centering switch. There is only a slot at the top and I turned the wheel all the way put back the switch and if I turn all the way the other direction at about 85% there both motors turn on and it wants to go straight? Anybody know something could help a fella out?
  • Posted 10 Jan 2011 23:19
  • By Dave T
Make sure the chain is set correctly, also the feedback encoder is set correctly. It might also pay you to ensure that there are no mechenical bind ups, such as load wheels moving on the hub or the drive tyre moving on the hub. These will cause similar problems to what you have described.
  • Posted 12 Jun 2007 20:59
  • By rory_p
  • joined 12 Jun'07 - 1 message
  • New South Wales, Australia
Normely the code's from 70 up Thats problem with your box
Why you change the encoder !!
END THE LEDS LIGHT UP WHEN YOU MOVE THE STEERING ON YOUR BOX
End what are the measerments on the box How meny volts you got
john
Netherlands
  • Posted 27 May 2007 07:13
  • By genjohn
  • joined 4 Feb'07 - 59 messages
  • NB, Netherlands
