Thank you, feebs. I found the fuse5 located on the left hand side of the front cover. Now the forklift runs and lifts as usual. However, the service manual would be very useful in the future if you can send it. I would like to buy one if you can sell.
if I remember right its located in a black fuse box to the top left side of the cpu and it should be 10amp rated. If you get totally stuck I f7nd out some technical data for the truck and send it to you. If totally stuck the fuse is located inbetween the keyswitch and main contactor on P1 wiring. if its not that then you may need to start more complex circuit testingbut I can send you the manual if needed.
Thank you, feebs.
Battery has 60% remains.
Where is the F5 fuse? F1-F4 are fine. I saw one part look like fuse case, but could not open it. It is located on the left hand side behind the CPU board box. Is it F5?
This codes is materials handling circuit abnormality, check battery and f5 fuse firstly, basic stuff first. Then check wiring and connectors to main cpu board, pump motor and contactors. Check for blown fuse, bad connectors and shorts in wiring. Report back and we can look at more indepth causes.
