Toyota 5FGC25
When turning the Steering wheel it seems to tighten up, we suspect it may be the steer cylinder by-passing on the piston seal. Has anyone had this problem in their travels ???? Maybe the Steering Box ??????Any help would be appreciated
  • Posted 27 Nov 2008 06:28
  • By Prentice
We found the Char-lyn steer box leaking and steering shaft universal and bearings worn. Replaced worn parts. Works good.
  • Posted 6 Dec 2008 01:59
  • By Prentice
Thanks guys, I will keep you posted
  • Posted 1 Dec 2008 23:40
  • By Prentice
In all likelihood the steering gear is worn allowing the pressure to by pass. You can try removing the bottom cover from the steering gear and tightening the big nut one quarter turn.
  • Posted 1 Dec 2008 23:21
  • By duodeluxe
  • United States
duodeluxe
does the "tightness" happen in relation to the position of the steering hand crank (wheel on the steering column) or in relation to the positions of the steering axle linkage (wheels on the ground) and does it change any if the steer avle wheels are up off the ground?
  • Posted 28 Nov 2008 23:28
  • Modified 28 Nov 2008 23:44 by poster
I would check the steer orbitrol along the column Rich
  • Posted 28 Nov 2008 09:07
  • By rich_k
  • joined 30 Oct'07 - 108 messages
Linde Material Handling
