toyota 5fbcu18 will not move no fwd or rev
i have a toyota electric sit down model number 5fbcu18 it tries to move but doesnt if you jack up lift the wheels will turn to wide open speed but when on ground it will not any help owuld be greatly appreicated no codes appear on dash
  • Posted 18 Mar 2013 21:31
  • By BigKelly
  • joined 18 Mar'13 - 3 messages
  • New Jersey, United States
I found bad drive motor test fine per Toyota but I ran power cables to a known good motor and everything worked like it should you would think it would code out with a bad motor but didn't
  • Posted 19 Mar 2013 23:30
  • By BigKelly
i suppose you have already checked the battery?
take a voltage reading (no load)
then activate the hydraulics and take a reading and see what it drops to.
On a 36v system it should read about 37.5 to 39v fully charged, and when loaded it shouldn't drop below 36v.
now there are some other possibilities that can cause no/slow drive without displaying codes like:
-bad directional contacts
-faulty power cable
-partially blown power circuit fuse
just some things to check for, there may be some other things some others here may know and post about but these are things off the top of my head that come to mind.
good luck
  • Posted 18 Mar 2013 23:15
TCM FHD105Z
Taylor TT300
Libiao Robotics
Deborah Baker Deborah Baker
Muncie, IN, United States
