TOYOTA 4FB15 "F0" Error code
Sometimes we got a "F0" code on the LCD. The forklift works fine but the steering doesn't work. We turn on/off the key and the steering works fine again.
Can you please let me know the meaning of this error code?.
S/N: 4FB15-11358
thanks
  • Posted 17 Nov 2008 21:33
  • Discussion started by manuel_g
  • Sevilla, Spain
I recently had a nissan electric truck with a similar problem, it had a steer contactor which would not energise and was comming up on the dash as steer fault. What I found was an earth fault in the steer motor had caused the system to shut down the steer contactor. We disconnected the motor which then energised the contactor, cleaned the motor out and put it back together and seemed to work fine. Its worth a shot checking out the steer motor to begin with.
  • Posted 21 Nov 2008 03:33
  • Reply by elektrodrive
i would check steering motor, maybe your brushes is worn or your armature could be dirty. i'm not to sure on your model, but our machines has steering contactor. could be that your tips are giving you a problem.
  • Posted 20 Nov 2008 22:28
  • Reply by quintin_k
  • Eastern Cape, South Africa
The fault code is related to the power steer circuit. Could be just a bad connection in the wiring of the power steer controller as its intermittant.
  • Posted 20 Nov 2008 03:38
Sorry, I made a mistake, the correct model is 5FBL15
S/N: 5FBL18-10757.
It's the same error code?.
  • Posted 18 Nov 2008 19:30
  • Reply by manuel_g
  • Sevilla, Spain
Check under battery. There should be two silver coloured electrical components side by side. Can't remember proper term for them check connectors first then check components. Let me know how it goes. Rich
  • Posted 18 Nov 2008 10:05
  • Reply by rich_k
ERROR CODE FO (DISPLAYED ONLY WHEN EHPS IS INSTALLED):
MAIN EHPS CIRCUIT ABNORMALITY
does this mean any thing?
  • Posted 18 Nov 2008 04:45
  • Reply by upliftUK
  • leicestershire, United Kingdom
kjghkjhkh
Enforcer FLBAXT25
Toyota 8FGCU20
Flesherton, Ontario, Canada
Louisville, KY, United States
Dubuque, IA, United States
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
