Toyota 2FBCA15 No Travel
I have lift/lower and steer motor comes on when requesting travel. Travel contactors do not come in.(Yes, this is a dinasaur!) Need a schematic to find why I don't have 36vdc to F and R switches. PLEASE HELP ME!!!
  • Posted 21 Apr 2012 08:01
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
Hi, I have read this post.. and I have a problem with the speed, is not running very fast, I need to know if you can help me with the Manual, I would be grateful.
Thanks in advance
Juan Sanchez
  • Posted 9 Mar 2013 02:33
  • By CoreRD
  • joined 9 Mar'13 - 1 message
  • Santiago, Dominican Republic
Thanks for you useful input. Everything is a help.
  • Posted 22 Apr 2012 13:20
  • By 1sharpdog
David Sharp
well i stand corrected
the model number looked very similar to the one i was working on
looks like rick would be more helpful, sorry i couldnt help more
  • Posted 22 Apr 2012 13:10
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
If this is the rick that I think you are, you are the best in the industry on toyotas. I will remind you monday and wish you would have returned my calls. Thanks in advance for the help!!
  • Posted 22 Apr 2012 12:31
  • By 1sharpdog
David Sharp
david, i have a schem but not on pdf, i will have to scan and e. remind me monday. "you should be able to figure out who i am". if not.........you gonna need more than a schem
  • Posted 22 Apr 2012 07:01
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
Actually, this is a four wheel unit and I pretty sure it is a 2fbca15, I have seen 2fbce15 and 2fbc15 models. But will follow your advice and check frame for any other models. Still doesn't help chasing these wires. Alot of shop wiring and bandaids on this unit.
  • Posted 22 Apr 2012 02:29
  • By 1sharpdog
David Sharp
double check that dataplate, check to see if its been slapped over another dataplate, that model number i bet is not accurate.
this a 3 wheel sitdown electric i presume?
check the frame on the left side floorplate just in front of the battery plate, the serial number will be stamped there as well beginning with the model number then a dash (-) followed by the serial.
The contactors are in a panel on the left side of the truck near the back end if i'm thinking of the right model.
go in there and make sure there are no welded contactors (stuck closed)
Hope this helps, i dont have any diagrams but i am currently working on a toyota at a customer that is almost the same model (2FBCE15) but the accurate model number turned out to be a 2FBC15 when i looked behind the dataplate on the origional one and compared it to what was stamped on the frame too. ;o)
  • Posted 21 Apr 2012 23:55
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
