Cat Lift Trucks (& Caterpillar) NR3000:
Tilt problem
The reach works fine. The problem is it always reaches. When tilting, the reach works at the same time. Same with side shift. Lift is ok. I checked harness all the way from control unit thru the mast and reach arms. No shorts or opens. Any other ideas? Could use any other ideas. Thanks
  • Posted 15 Feb 2013 06:25
  • Discussion started by h80xl2
  • Wisconsin, United States
yeah i forgot about those... doh!
of course during the troubleshooting of the circuits you would have ran across those anyways.
well done finding that! :o)
  • Posted 22 Feb 2013 21:31
  • Reply by swoop223
Turns out one of the relays under the steer handle was burned closed so the reach was always on. Replace the three relays for the reach, tilt and side shift. Fixed the problem. Thanks for your help.
  • Posted 22 Feb 2013 01:47
  • Reply by h80xl2
Tom
check your function solenoids and cartridge valves at the main manifold block on the carriage. It sounds like one of them is not working and not diverting fluid correctly.
  • Posted 15 Feb 2013 21:33
  • Reply by swoop223
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
TCM FD115-3
Ncn 85TH
Ncn 85TH 2017
