Throttle body
Actually it's an H120XM. I have replaced my third throttle body on these trucks to date. They are not directly activated by the throttle pedal, the pedal moves the stop and a spring is supposed to open the butterfly. But on the bad ones it hangs up and won't move. Does anyone know of a rebuilder or repair kit for these? They cost over $500 apiece.
  • Posted 15 Nov 2006 02:43
  • By thomas_e
  • joined 26 Oct'06 - 5 messages
  • Maryland, United States
*update*
Checked with the shop guru, and they no longer soak these things.
They pull the throttle shaft and clean the bore reaaly well.
Then, they assemble unit using atf as a lube.
They've found that dirt gets sucked in past the shaft seal and that's what siezes these.
  • Posted 17 Nov 2006 00:59
  • By mike_n
  • Alberta, Canada
We've created our own little exchange program for these.
The stuck one comes back and gets soaked/cleaned up and the clean one goes back.
  • Posted 16 Nov 2006 02:04
  • By mike_n
  • Alberta, Canada
