Has code 524262-14 No Trans Braking
Can anyone tel me what to check for this code524264-14, in the manual it says "Special Condition" what are they refering to, forklift runs normal other than the code on the dash.
  • Posted 28 Mar 2017 04:41
  • Modified 28 Mar 2017 05:46 by poster
  • By pelayos1
  • joined 20 Sep'11 - 8 messages
pelayos1@msndotcom
Mismatched passwords usually means someone changed the VSM or the display. This will cause the truck to not operate. You should be seeing a display mismatch error on the display unless the display and VSM were changed at the same time. The only way to reset the display password is to have a service level password or use the laptop to reset.
  • Posted 29 Mar 2017 23:22
  • By BREWSKI
Thank you for the advise BREWSKI I will perform a calibration and check the pins and connectors, the sensor have been replaced with known good ones from a second forklift on site, I did find by going into the settings that the serial number in there does not match the serial number on the data plate of the forklift, Do you know if that could be the cause of that code?
By any chance do you know any master word I can use to go into the menu and reset the password, the basic password does not work on the second forklift there. And thanks again for your help.
  • Posted 29 Mar 2017 15:56
  • By pelayos1
pelayos1@msndotcom
This usually indicates an erratic input from either the TISS or TOSS sensor. Do A calibration first then change out one at a time or replace both sensors. Also check the connectors for dirty or bent pins.
  • Posted 29 Mar 2017 00:49
  • Modified 29 Mar 2017 00:51 by poster
  • By BREWSKI
Ice 24INCH-AUTO-SCRUBBER
USD6,396
SMV (Konecranes) 16-1200C
