acceleration-potentiometer-driving
model H30D serial H2X393T01644. I received this Linde H30D diesel at no cost. Secured starter that was hanging by one bolt, installed a new battery. Unit fired up but had no travel. Come to find out, the potentiometer was taken out. Probably to use on another unit in their fleet. Installed a new one. Must this be calibrated by software? I have been a tech for 14 years but have never serviced a Linde. Seems to be a great machine. I am currently learning about the hydrostatics. Problem is it seems as though the "brakes" are dragging. I understand that upon acceleration the brakes are released and then applied when decelerating. It has single accel and brake pedal. Hopefully it is a simple service call for calibration.
  • Posted 23 Jan 2017 06:20
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
Thanks for reply Lindetech. All is good. You were correct. No brake drag, just a lack of knowledge on my part. Thanks again.
  • Posted 15 Feb 2017 13:17
  • By tonymfg
Pedals will need to be calibrated once a new pot has been fitted to the pedal assembly.
Brake drag I would be checking that you are maintaining a steady pressure on the BR port of the brake valve.
More likely It may just feel slow due to the pedal pot not being calibrated or the travel speed has been slowed via laptop.
  • Posted 27 Jan 2017 07:34
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
