Forklift overheats
P6000 cat with k25L Nissan engine overheats under load. It has new radiator ,water pump, head gasket, thermostat, senders.Have tested coolant for combustion gases.Checked cylinders for coolant. I'm out of ideas
  • Posted 13 Jan 2017 07:29
  • Modified 13 Jan 2017 07:31 by poster
  • By Freddy
  • joined 13 Jan'17 - 5 messages
  • Kansas, United States
Installed new head cured heating under load now several months later it will overheats after 30 minutes of light use.and the temperature guage is slightly above normal before you get it to overheat
  • Posted 28 Jul 2017 03:06
  • By Freddy
  • By Freddy
When you say overheating are you loosing coolant or getting any trouble codes? If your inching pedal is out of adjustment it can cause high transmission temps that lead to overheating.
  • Posted 17 Jan 2017 17:08
  • By shovel_fx
  • joined 11 Mar'12 - 41 messages
  • Illinois, United States
Ya has a new fan to.thinking head is probably cracked and just not showing up on tests
  • Posted 13 Jan 2017 22:54
  • By Freddy
I have had plastic fan blades get worn and not move air well. Usually this is with lots of idling and i haven't seen this on any cat/mitsu yet but if your stumped it's worth looking at.
  • Posted 13 Jan 2017 22:45
  • Modified 13 Jan 2017 22:49 by poster
  • By stam
Toyota 3FD100
Deborah Baker Deborah Baker
