Wont go up wont go down,
I have a crown WP-2335 that will not move up or down. I was advised to change the lowering solenoid. I did and it worked for a few hours now it won't go up or down. What now?
  • Posted 30 Dec 2016 02:47
  • By Stalinski_Murk
  • joined 30 Dec'16 - 4 messages
If it's broke, I didn't do it.
Remove the top cover/bell and inspect it visually. As long as it not pitted or grooved your fine.
  • Posted 20 Jan 2017 13:13
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
How would I go about checking the com?
  • Posted 12 Jan 2017 02:13
  • By Stalinski_Murk
Check the com if it's OK just new brushes other than that skim and new brushes if it's to far gone replacement motor
  • Posted 12 Jan 2017 02:12
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Ok I checked voltage and was getting 24v. Still would only make clicking noise when I tried to lift. So, I decided to smack the motor with a rubber mallet. To my surprise, it began lifting again. What now? Do I need to replace the motor?
  • Posted 12 Jan 2017 02:01
  • By Stalinski_Murk
Check for continuity across pump motor terminals, if lift contacor is clicking you probably have worn brushes
  • Posted 6 Jan 2017 09:21
  • By techno_nz
  • Canterbury, New Zealand
I would put a volt meter on motor terminals to see if you are getting voltage. If not check the cables and connectors.
  • Posted 30 Dec 2016 03:25
  • By BREWSKI
No they are down. And the pump is not running. All that happens is clicking.
  • Posted 30 Dec 2016 03:02
  • By Stalinski_Murk
are the forks elevated? Is the pump running?
  • Posted 30 Dec 2016 02:59
  • By BREWSKI
Esie Cortez Esie Cortez
