LIGHTS
I replaced the ecu , forklift runs normal ,but 4 lights stay on , do I need ot reset the ecu , how ?
  • Posted 29 Dec 2016 03:14
  • By robin_j
  • joined 1 Oct'15 - 4 messages
Yep that trucks that were for the US had control levers and a ECU which replaced the MAP sensor.
  • Posted 29 Dec 2016 23:02
  • By Partsguy5
It is lever control
  • Posted 29 Dec 2016 22:46
  • By robin_j
well if it's levers I've never not in the UK anyway seen a 4g63 with a ecu
  • Posted 29 Dec 2016 17:57
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Her truck should have the levers
  • Posted 29 Dec 2016 09:29
  • By Partsguy5
Is it fingertip control. where is controller fitted. Did you set the dill switch you will have a led by switch this will give you a flash code
  • Posted 29 Dec 2016 08:32
  • Modified 29 Dec 2016 08:53 by poster
  • By alanmitsi
This one does have an ecu P/n 9116515800 , lights that stay on are battery ,red triangle,oil press ,water temp , we checked everything is good , truck starts runs good , just the lights... thks
  • Posted 29 Dec 2016 08:09
  • By robin_j
A 25k will not have a ecu.Has a 4g63. is it fc or levers only light that would be on is the red triangle and no hydraulics if it is fc other than that it would be dash symbols
  • Posted 29 Dec 2016 05:37
  • Modified 29 Dec 2016 07:46 by poster
  • By alanmitsi
Michel Denis Michel Denis
