Code D-98
Hi there, I have this code D-98, the dashlights it's flashing every 1 second, some budy can help me with this issue ?
S/N AT19E80073
  • Posted 9 Dec 2016 09:21
  • Modified 9 Dec 2016 09:23 by poster
  • By mynor
  • joined 21 Apr'16 - 6 messages
Has it got a DPF filter? The only code I can find in the book for D-98 is DPF warning, soot load percent is severely high.
  • Posted 27 Oct 2023 06:20
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
Not sure, runs fine. every now and then will act like no power going up slight incline but is mostly fine. was told the code was for oil velocity so changed it added new oil pressure sensor also still no change. serial number is AT19E80075
  • Posted 27 Oct 2023 04:51
  • By Rob_Walter
  • joined 26 Oct'23 - 4 messages
DPF warning?
  • Posted 27 Oct 2023 02:48
  • By andrew_k
Did you ever figure anything out with this, im having the same issue and code as you with lights flashing.
  • Posted 26 Oct 2023 04:56
  • By Rob_Walter
Terberg YT220
Crown CG33P5
Terberg YT220
Crown CG33P5
Terberg YT220
Crown CG33P5
