Battery Not fully Charging. According to unit. And code 867
When I put truck on charger it goes through cycle. Charger shuts off. When I plug battery into truck the charge indicator shows battery at 84%. I believe I need to reset discharge indicator am un sure of how too though.
  • Posted 18 Oct 2016 05:24
  • By twoeey
  • joined 15 May'15 - 49 messages
Sounds like you found your problem. Cells are roughly $500 give or take...a few hundred, all depending on battery type and size. Wouldn't put much money in a battery older than 4 years, depending on your application.
  • Posted 21 Oct 2016 11:46
  • By AceMechanic
  • joined 21 Oct'16 - 8 messages
  • Kansas, United States
Both 12 and 18 were at less than 1.75 volts gravity level of 12 was 1100. 18 was 1000
  • Posted 21 Oct 2016 11:36
  • By twoeey
I did load test in process found cell 12 and 18 bad. Battery is less than 2 years old.
  • Posted 21 Oct 2016 11:33
  • By twoeey
I would perform a load test on the battery. Do you know the age of the battery? Battery s/n?
  • Posted 21 Oct 2016 11:30
  • By AceMechanic
It sounds like you have a battery problem.
  • Posted 19 Oct 2016 05:57
  • By BREWSKI
I let it run down to 40% charged it. Till charger shut off it then read 100% soon as I used carriage and turned key off and back on it dropped to 70%. Could there possibly be something wrong with the regen from hydraulic motor. I believe that when the mast is lowered it recharges battery some how? Or am I incorrect in my understanding of this?
  • Posted 19 Oct 2016 02:34
  • By twoeey
I am not sure if this applies to your truck but some of the new systems require the battery to be below a certain percentage before a recharge will reset the display. Try running the truck until the display reads below 50%. Then recharge and check it.
  • Posted 18 Oct 2016 23:24
  • By BREWSKI
I put on charger again let it charge till it said it was charged. Tested voltage at battery 40.10 v./ 39.5v at access 8 panel. On lift it shows battery to be at 61%.
  • Posted 18 Oct 2016 08:26
  • By twoeey
I did it was 37.85 volts. Though something happened when I used the carriage the voltage dropped from 84% to 61%. Going to top and back down 1 time.
  • Posted 18 Oct 2016 07:17
  • By twoeey
I WOULD CHECK BATTERY VOLTAGE FIRST BEFORE ANYTHING ELSE
  • Posted 18 Oct 2016 06:26
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Enforcer FLBAXT25
UN Forklift FBR25NQC3
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
