Slow raise.
Hi. Customer called saying forks lifting slowly. Found on free lift and after staging very slow raise. Tested the two sensors and altimeter. Even swapped them over with identical machine bought at the same time. Same issue. The screen that shows the fork height has four flashing dots. Have swapped screen (A8) swapped a5 checked all wiring etc and no error codes displayed. Any help is greatly appreciated.
[email address removed]
Michael.
  • Posted 24 Aug 2016 15:43
  • By KRLIFT
  • joined 20 Nov'15 - 11 messages
  • New South Wales, Australia
Check your email
  • Posted 25 Aug 2016 06:08
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
krlift at big pond dot com
  • Posted 24 Aug 2016 16:02
  • By KRLIFT
Also I have checked a5 led showing that the altimeter and two sensors are connected to a5. One turns on other turns off for the two sensors and the altimeter two led flicker opposite as I would expect.
  • Posted 24 Aug 2016 15:46
  • By KRLIFT
Linde Material Handling
