ERROR CODE
ERROR CODE 035 SHOWING ON THIS MACHINE CAN ANYONE IDENTIFY PLEASE
THANKS PETER
  • Posted 23 Aug 2016 00:52
  • By peterb
  • joined 23 Feb'16 - 125 messages
  • lancashire, United Kingdom
From memory A04 is an anomaly in the manual, I think it says shunt wires on wrong way round but unless you have removed them in the first place then this cannot be the case.
What it normally is is bad connections on the multi plug on the controller, the pins are aluminium and the contacts in the plug are metal so you get a very thin layer of corrosion as they are dissimilar materials, you may not even be able to see it.
The best thing to do is remove the plug (make sure you disconnect the battery as it can blow the controller if still powered up) spray contact cleaner on the pins and in the plug and push in and out multiple times to clean off corrosion, then blow out with air, re connect and give it a try, came across this loads of times on LE , KE and JE Boss machines with Bosch LT controllers, not saying that its this 100% but worth checking.
  • Posted 2 Apr 2020 23:50
  • By danny_k
can i please know what A04 is too please?
[email address removed]
many thanks
  • Posted 2 Apr 2020 20:56
  • By martyn_harrison
  • joined 2 Apr'20 - 1 message
  • United Kingdom
Hi, if you can help me, I am working on forklift Boss LE18HV and have following error code AR04. Thank you in advance!
Edit
  • Posted 14 Dec 2019 07:47
  • By dragan_p
  • joined 14 Dec'18 - 28 messages
  • Bosnia And Herzegovina
mbprolic hotmail com
mark, thanks for replying we will check it out
  • Posted 23 Aug 2016 01:35
  • By peterb
HELLO PETER, COULD IT BE THAT THERE ARE 3 CONTROLLERS MP1514? IF SO ERROR CODE 035 IS A PROBLEM WITH THE ACCELERATOR (NO ZERO POSTION)
REGARDS
MARCB
  • Posted 23 Aug 2016 01:30
  • By marcb
  • joined 10 Jun'14 - 221 messages
  • ANTWERP, Belgium
Taylor TT300
Unicarriers FD80-2
Oxford Ct, United States
Esie Cortez Esie Cortez
