code E 85
This lift will stop pulling forward and go in reverse only,and code e 85 will come up.restart lift a couple of hours later will work fine for about 15 minutes.
  • Posted 26 Mar 2008 12:46
  • By harry_w
  • joined 12 Mar'08 - 5 messages
thats great harry_w,
but may i add a comment here relating to this issue.
i have found out also in the past that what makes these valves stick in the first place is dirty transmission fluid.
if the transmission isnt serviced regularly the fluid gets dirty and the dirt gets into the shuttle valve and makes it stick. When it gets to that stage you have to take everything apart and clean it to solve this problem. And i also have seen a few of these just go bad from bad coils as well.
Of course it giving an error code means an electrical issue so sounds like the coil was bad.
Laterz,
  • Posted 21 Jul 2008 00:07
  • Modified 21 Jul 2008 00:10 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
sorry took so long to reply replaced selonid problem solved
  • Posted 20 Jul 2008 10:57
  • By harry_w
Trans solenoid, Wiring to solenoid from VCM, Diode in harness wired in parallel with solenoid, Vehicle Control Module
  • Posted 20 May 2008 09:27
  • By carl_v
  • joined 12 Oct'07 - 76 messages
mod and ser might help
  • Posted 26 Apr 2008 09:53
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Seems to be a faulty solenoid on the control valve.
Try swopping the wires around when the one direction stops working.
Then you'll know for sure.
  • Posted 25 Apr 2008 04:30
  • By wonderphil
  • joined 6 Sep'06 - 15 messages
  • Mpumalanga, South Africa
Thank god for forklifts.
Mitsubishi FGE35AT
UN Forklift FD35T
Yale Lift Truck Technologies
