event code 124
Hello everyone. For the past few months the service light has come on randomly and the lift goes into slow mode. The event code is 124 and is the only code. Everything seems completely fine until the service light shows up. Even in slow mode still works like normal. I can't find anything on this code at all on the internet.
Any help or information would be greatly appreciated. Thanks!
  • Posted 9 Aug 2016 02:45
  • By D4rk5t4r
  • joined 9 Aug'16 - 1 message
You might need to calibrate it, but that's only possible in the service menu. Like most things it limits it to crown techs to repair
  • Posted 19 Aug 2016 09:31
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
Code 124: Steer command encoder (ECR4) is out of range (AC hydraulic system only)
If it works ok 99% of the time its probably a loose wire/connection at the encoder or at Access 1
  • Posted 15 Aug 2016 10:13
  • By techno_nz
  • Canterbury, New Zealand
Yale Lift Truck Technologies
SMV (Konecranes) 4632CC5
SMV (Konecranes) 16-1200B
