Secondary boom not lifting
I have a Z30/20N and the secondary boom will not lift. The manifold is pressurising and the cylinder starts to lift just a fraction and then stops. i replaced the counterbalance valve and i am still having the same issue. Right not i have no idea what to check.
  • Posted 5 Aug 2016 04:07
  • By sbhbrett
  • joined 18 Mar'16 - 17 messages
no
the only purpose for the auxillary system is to operate the boom if the main power source goes dead, it is a safety system put in place to get you down to the ground in a case like that. The auxillary motors run on their own circuit.
But that is interesting that the boom works in that circuit and not in the normal one.
Now i know this let me check a couple more things and i'll get back to you if i find something.
  • Posted 13 Aug 2016 08:00
Well i have found that the secondary boom lift will work if you use the auxiliary pump switch. shouldn't the aux pump come on with the primary when trying to raise the secondary boom?
  • Posted 13 Aug 2016 03:47
  • By sbhbrett
yes that is my understanding also.
  • Posted 12 Aug 2016 00:55
  • By sbhbrett
just to clarify your interpretation of which boom is primary and which is secondary
- primary boom is main horizontal boom arm with extension cylinder that platform is connected to
- secondary boom is the main boom sections (the Z section that is for vertical elevation).
although you have changed the primary and secondary porportional valves with no change in operation i just need to clarify this so i can check a couple more things out as possibilities.
  • Posted 11 Aug 2016 21:25
the full model and SN are :
Z30/20N RJ
Z30N14-15407
As you suggested I tried swapping the primary and secondary directional control valves and the problem stayed. I also tried swapping the relief valves and still no change. Also yes the problem is the same at the platform and ground controls.
  • Posted 11 Aug 2016 00:05
  • By sbhbrett
does this happen using platform and ground controls?
then yes i would look at the main manifold valves.
what is the full model and serial number of this unit off of the name plate located inside the tractor unit on the panel beside where the boom arms are.
  • Posted 10 Aug 2016 22:24
Well i repacked the cylinder and i am still having the same problem. Could the cylinder valve block be the trouble?
  • Posted 10 Aug 2016 05:36
  • By sbhbrett
I checked pressure on each line coming out of the manifold and have 1600-1400 PSI going to the secondary cylinder. So eyther the seal is bad on the piston and there is an issue in the valving on the bottom of the cylinder. Does this sound right?
  • Posted 6 Aug 2016 02:24
  • By sbhbrett
brewski is on track here
get a test guage (5000psi) and put it in the test port on the function manifold. The test port has a quick disconnect fitting with a rubber cover on it, you will need to get the opposing (female) quick disconnect of the correct size to plug onto this. Or you can just remove that and tap straight into the threaded port , either way works.
Verify that you are getting pressure when activating that function.
system relief pressure should be around 2800 psi
primary boom down 1400 psi
secondary boom down 1600 psi
(these figures are based on a specific serial number range and may not apply to your unit, you will have to look up the manual for your specific serial number range on the genie website in the service manuals section).
Verify the problem is consistent between the platform controls and the ground controls to help isolate where the problem is.
If it does the same from both control panels then your problem is in the function manifold valves. Since you've replaced the counter balance valves on the cylinder i presume you still have to locate and check the 'check valves' for the secondary boom function and see if either one of those are damaged.
According to one troubleshooting manual i'm looking at you can test the primary and secondary boom directional valves by swapping them and see if the problem follows/moves to the function primary, if so then replace the directional valve.
Also when you activate the secondary boom function if you get 2800 psi then there is an issue with the valves, it should not be that high if the cylinder is moving and not bottomed out. (follow the proceedure above)
First and foremost you need to have the correct manual for the serial number range of your unit so verify this before following my instructions above.
AND if you are unsure about any of this then by all means call a professional aerial lift tech. Remember safety is first and foremost and these machines are personnel carriers so they should only be repaired by trained service personnel.
  • Posted 5 Aug 2016 22:57
  • Modified 5 Aug 2016 23:08 by poster
Can you put a pressure gauge in the cylinder feed line? Maybe the cylinder is hydraulically locked due to a blown seal.
  • Posted 5 Aug 2016 22:29
  • By BREWSKI
Unicarriers FHGE35T5S
Toyota 8FGCU25
Flesherton, Ontario, Canada
Todd J Doxsee Todd J Doxsee
Sales operations, Heli
Chief financial officer, Cyngn
Executive vice president and chief commercial officer, East Penn Manufacturing
Philadelphia, United States
Davenport, IA, United States
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
Zhejiang UN Forklift Co., Ltd
Brothers Adolf ("Adi") and Rudolf ("Rudi") Dassler split their shoe company after WWII due to a bitter feud, and established the rival companies of Adidas and Puma. Their personal animosity and business rivalry divided their German hometown Herzogenaurach. The town became known as "the town of bent necks" due to the intense loyalty to each brand.
Toyota 8FGCU25
