393 BUE ENGINE not start
please tell me, why the truck has starting trouble and what are the checking points.
  • Posted 18 Jul 2016 01:50
  • By mohanraj_k
  • joined 18 Jul'16 - 5 messages
  • karnataka, India
Might be a crank shaft sensor under oil filter. Get lap top and check for codes. Load test battery. Just because it cranks good doesnt mean controller getting 12 volts. What is serial number?check fuses.
  • Posted 8 Oct 2016 14:14
  • By edward_m
  • joined 11 May'15 - 111 messages
Thank you for your reply. cranking speed is good. based on your information i will check engine controller.
  • Posted 21 Jul 2016 08:40
  • By mohanraj_k
  • karnataka, India
Make sure engine is turning over at a good speed. I had a situation where the engine turned over slow because of an alternator that locked up. This slowed the engine cranking speed down enough for a no start.
When you turn the ignition switch to the run position does the glow plug light blink. This would let you know that there is an error code stored in the VW controller. You would need to get a laptop with the Linde Pathfinder program hooked up to the truck and get the codes out.
Check for power at the fuel cut off solenoid on the injection pump.
Do you have fuel squirting out of the injection lines if you loosen them up at the injection nozzles and crank the engine over?
Was this a situation where the lift truck engine died, or it did not start after a normal shut down?
  • Posted 20 Jul 2016 23:03
  • Modified 20 Jul 2016 23:04 by poster
  • By IFD45
  • joined 28 Feb'13 - 31 messages
  • Wisconsin, United States
IFD45@mail.com
Thank you for your valuable information. Timing is correct and no damage found in fuel hose. Please tell me electronically what are the checking points like sensors and other thinks. Crankshaft sensor and immobiliser unit is new one.
  • Posted 20 Jul 2016 21:21
  • By mohanraj_k
  • karnataka, India
Make there are no holes rubbed through in the fuel hose prior to the injection pump. If it is starting hard it sounds like it is pulling air into the injection pump. The timing could also not be correct.
  • Posted 20 Jul 2016 21:01
  • Modified 20 Jul 2016 21:01 by poster
  • By IFD45
IFD45@mail.com
Toyota 3FD100
Unicarriers FHGE35T5S
GemOne
