No reverse
Have a ep16kt 48v operator hit a bump and it shut down. code 60 found bad connection at logic board and repaired. Now unit fires up goes through its motions as it should drives forward steering works hydraulics work but when you put selector in reverse back up alarm sounds but contacts don't engage and motors don't engage. No trouble codes. Has any one ran into this before?
  • Posted 7 Jul 2016 04:16
  • By Deuce
  • joined 27 Jan'16 - 26 messages
  • Michigan, United States
Hadv another 1 do it. Found issue. Replied to your original post.
  • Posted 19 Jun 2020 23:38
  • By Deuce
Jeff Sheldon
Yes but for the life of me i cant remember what it was.
  • Posted 15 Dec 2019 05:18
  • By Deuce
Jeff Sheldon
I am having the same issue with ours. As far as I know we didn't have the issue with the connector but it won't go in reverse and gives no code. Did you ever find a solution?
  • Posted 14 Dec 2019 22:37
  • By printer
  • joined 23 Jan'19 - 6 messages
Mitsubishi Logisnext FD25T5M
Terberg RT223
Oxford Ct, United States
