yale palletjack
alarm code 01 red light flashing help
  • Posted 15 Mar 2008 00:00
  • By squidman
  • joined 12 Mar'08 - 23 messages
  • Rhode Island, United States
A 01 code is displayed for several reasons. A battery charger connected.Safety switch closed during start up"DEAD MAN". Any travel or hyd switch closed during start up.If all check ok you will need handset to trobleshoot
  • Posted 27 Apr 2008 23:20
  • By HILLBILLY
  • joined 12 Feb'08 - 4 messages
If it ain't broke don't fix it.If it works leave it alone.
no, wish i did i am looking though any suggestions with out one thanks squidman
  • Posted 17 Mar 2008 10:23
  • By squidman
Do you have access to a ZAPI hand set? You will have to use one to check the control card and do further checks
  • Posted 17 Mar 2008 04:07
  • By roadrat
  • joined 24 Jan'08 - 186 messages
"ARE WE HAVING FUN YET?"
it continuously flashes with alm 01 cont check ok
  • Posted 16 Mar 2008 23:57
  • By squidman
If you are getting one flash check wire you described in other post for continuity between tiller card and controller---check connector plug also ---controller not communicating with tiller card
  • Posted 16 Mar 2008 19:56
  • Modified 16 Mar 2008 19:57 by poster
  • By roadrat
