Brake
Hi , I have a electric brake on a SA swingreach that is giving me trouble , the brake heats up and starts to drag, I replaced the brake thinking it was a weak coil but the problem is still there , lasts only a few hours before the battery starts to drop off. can this be a motor problem ?? I did try a new battery in the machine brand new and this still happens.
  • Posted 27 Apr 2016 03:50
  • By milford
  • joined 5 May'15 - 9 messages
  • Alberta, Canada
Low voltage can cause problems with electric brakes. A fully charged battery should operate this truck for six to eight hours, unless you are doing an excessive amount of lifting. What was the voltage when this "new" battery was installed; and what was the voltage when the problem reoccurred?
Brake clearance can also be a problem. The gap between the coil housing and the upper pad assembly should be.23 -.58mm. When the brake is released the measurement above and below the rotor should be nearly equal (.o51-.533mm)
There could also be several problems with the brake control circuit.
  • Posted 10 May 2016 10:32
  • By louis_p
  • joined 13 Feb'16 - 24 messages
  • Mississippi, United States
