error code
error code 60 what is it? is it the "logic board" or can it be something else???
  • Posted 16 Apr 2016 01:44
  • By PRISCOFL
  • joined 16 Apr'16 - 1 message
DTC 60 is Display Communication Fault
if truck operation is normal even when code is present
possible causes are:
faulty main harness, faulty display unit or faulty logic unit
- disconnect connector CN3 of controller, disconnect connector CN8 of display unit.
- check continuity between CN3-14 and CN8(149)
- check continuity between CN3-16 and CN8(150)
- check continuity between CN3-23(140) and CN8(152)
- check continuity between CN4-13(4) and CN8(151)
if you have continuity (not shorted) then replace display unit
if you have continuity (shorted) then repair or replace harness
if none of the above solves the problem or you find no problem then replace logic unit.
if truck operation is inhibited when code is present
faulty logic unit
hope this helps
good luck
  • Posted 16 Apr 2016 06:55
