linde 393 error 236
hello we have a linde 393 h35t from2008 and it shows error 236 wich is Incompatibility between signal/reference potentiometer tilting. we changed the tilt angel sensor, after that we calibrate the tilt sensor, but it still making the error 236 , 8-10 times in a working shift.
what else could it be?
  • Posted 31 Mar 2016 01:38
  • By daniel_a
  • joined 14 Mar'13 - 121 messages
  • ARGES, Romania
The problem is not in joysticks probably you have to give some tolerance while you celebrate the tilt angel because if you will put zero tolerance the mass is so long thats why it is not come on same position give some tolerance 5 and you will not have this problem again
  • Posted 30 Apr 2024 04:05
  • By Manish_Jangra
  • joined 3 Apr'24 - 1 message
  • Portugal
Mnish
Change the joystick, and recalibrate the system.
Mirko
  • Posted 31 Mar 2016 21:10
  • By mirko_c
  • joined 16 Jan'14 - 166 messages
  • Reggio Emilia, Italy
L236 is joystik ploblem
  • Posted 31 Mar 2016 07:05
  • By michel_v
  • noord holland, Netherlands
Have you tried calibrating or even replacing the joystick?
  • Posted 31 Mar 2016 06:45
  • By little_forker
  • joined 31 Jul'11 - 82 messages
is the linkage all ok that holds the sensor
  • Posted 31 Mar 2016 05:00
  • By kevin_k
