Steering Moves from locked position
anyone had a problem with the steering moving out of position after changeover of direction, locks initially but then creeps after a while. I suspect a seal is passing some where but without a hydraulic diagram or any tech info its difficult to pin down. Any help- appreciated.
  • Posted 25 Mar 2016 01:17
  • By johaanmikiel
  • joined 11 Aug'15 - 8 messages
  • east lothian, United Kingdom
Hi,
Just so you are aware the proxy sensors are only used to action the steering direction change and are not used once the steering direction change has completed (the 45 degree one is used for carousel but that is seperate). Most likley a passing seal on the rear cylinder. The UK services team can be emailed uk.services..combilift.com, just replace the 2 dots in the middle with the at sign and they will be able to help you. Combilift also has lots of technical information on the web site and knowledgebase that is available to dealers.
  • Posted 9 Aug 2021 22:17
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Possibility of a rear steer cylinder bypassing internally past the piston. Or by passing in the 6 port steering change over valve (valve locks fluid flow to rear steer when in side mode). But since its intermittent I would recommend looking into and installing the rear steer cylinder check valve kit (CPHY0455) if you have a rear steer cylinder p# CMR00024 as this kit was made to prevent rear steer cylinder from creeping.
  • Posted 5 Aug 2021 01:17
  • By BLey
  • joined 31 Jul'20 - 60 messages
By passing while sitting still or moving?
  • Posted 4 Aug 2021 23:57
  • Modified 4 Aug 2021 23:58 by poster
  • By Jones
  • joined 16 Aug'12 - 20 messages
What fixed your problem i am having the same issue?
  • Posted 4 Aug 2021 23:51
  • By Matt_Williams
  • joined 4 Aug'21 - 1 message
  • Tennessee, United States
Matt Williams
the solenoid that controls your rear tire hydraulic is likely bad
  • Posted 30 Nov 2017 16:24
  • By CamTron
  • joined 28 Jul'17 - 5 messages
  • Illinois, United States
Rear Wheel locks into place- then sometimes immediately, sometimes after a while drifts out of alignment. Checked proximity sensor, no dirt or debris and connection good. Only does it now and again, working perfect right now but I am hoping to find out what it is before it becomes a major problem.
  • Posted 31 Mar 2016 23:59
  • By johaanmikiel
Which wheel is creeping all or just one and is it creeping while using it or when its sat not being used?
  • Posted 25 Mar 2016 20:58
  • By danny_k
Unicarriers FD80-2
Tusk 350CGH20
Unicarriers FD80-2
Tusk 350CGH20
