won'the start
I amworking on a CAT P5000 it was running and just quit , it was giving me a code E-28 so I replaced the cam and crank position sensors then it started giving me a E-27 code I checked the plugs at the sensors and found a bent terminal I corrected that and the E-27 code went away , it tries to run but won't I checked the harness from the individual sensors to where it plugs into the main engine harness and that checks out ok so now I don't know what to do next.
  • Posted 6 Feb 2016 07:59
  • Modified 15 Feb 2016 19:16 by poster
  • By josh_a
  • joined 15 Jan'16 - 6 messages
  • Indiana, United States
It will start and run if you use starting fluid, but if you shut it off you will have to use starting fluid to get it started again , I am running out of ideas even had a CAT (Wiese) tech stumped.
  • Posted 15 Feb 2016 19:23
  • By josh_a
