Baker FMF-040 Fork Lift
I just purchased a used FMF-040 fork lift. From my research here and elsewhere it seems to be a Baker or rebadged Linde. Serial starts with 0 (oh).
There seems to be quite a few free resources (manuals, parts lists) for other models FJF.
Questions:
1) What does the lever/brake do on the floor to the right of the seat?
2) Is there a service manual for the FMF-040? Or is it the same as other models?
3) What is the max lift capacity? And does it decrease as the load rises?
4) What is the gross weight?
Thanks!
  • Posted 30 Jan 2016 13:46
  • By briankb
  • joined 30 Jan'16 - 12 messages
Showing items 1 - 20 of 29 results.
I have an FMF-040 also, and was wondering if you were able to find a manual for yours? I've been digging all over creation and haven't found one for the FMF-040. I can find other manuals on eBay FJD, FTD, FMD, FID, etc... but nothing for the FMF. Any idea if other models are the same. I just want to make sure I buy the right manual for our machine.
Thanks!
Ray
  • Posted 24 Dec 2024 05:23
  • By RazorBurn
  • joined 24 Dec'24 - 1 message
  • West Virginia, United States
Thank you! You rock!
  • Posted 15 Mar 2024 10:16
  • By Gary_Kitchens
  • joined 8 Mar'24 - 5 messages
  • Washington, United States
that one guy......
It is odd that the gears would be worn. Assuming they are and it is a Continental engine then the numbers will be stamped on the gears. The numbers should be something like F600....
  • Posted 15 Mar 2024 09:55
  • By duodeluxe
  • United States
duodeluxe
This forum setup is extremely old fashioned and very very difficult to follow a thread.
  • Posted 15 Mar 2024 09:50
  • By Gary_Kitchens
that one guy......
The timing cover is still in place, if there's part numbers stamped I will disassemble and make my start from there.
  • Posted 15 Mar 2024 09:49
  • By Gary_Kitchens
that one guy......
Do you have the old gears? If so, the part #'s are stamped into them.
  • Posted 15 Mar 2024 09:47
  • By duodeluxe
  • United States
duodeluxe
I don't know about his, but my email address is classykauto at gmail dotcom
Which has been removed for some reason, probably a rule I didn't read before signing up.
I am seeking timing gears for this motor, and I cannot date the rig or ID the engine because nobody has any googable info on this baker 2K lift.
  • Posted 12 Mar 2024 03:52
  • Modified 12 Mar 2024 09:30 by administrator
  • By Gary_Kitchens
that one guy......
I'm seeking the same info for my Baker-Otis FGD-040, I need timing chain and or gears, basically any information I can get in identifying the year of this lift and the flathead four cylinder engine.
  • Posted 8 Mar 2024 05:40
  • By Gary_Kitchens
that one guy......
What is your email address?
  • Posted 20 Apr 2017 21:23
  • By duodeluxe
  • United States
duodeluxe
Where could i contact you because most likely i would need to replace them.
  • Posted 15 Apr 2017 04:48
  • By misael_l
  • joined 12 Apr'17 - 3 messages
Misael Linan
Please post a photo. Most likely the two nuts that you are referring to are the brake adjusters. If you have a hard pedal and the truck doesn't stop then the brake shoes are oil soaked and must be replaced.
  • Posted 13 Apr 2017 22:16
  • By duodeluxe
  • United States
duodeluxe
Thank you everybody for the help provided in this forum. I do have a couple of questions.
I am working on this forklift because of no brakes, i have no idea of the model or serial number, since i couldn't find it anywhere. I have removed the wheels and looking in the back of the drums it has only 2 nuts, are this the one to be removed in order to have access to the brake system? when i do this will the axle came out with the drum?
  • Posted 12 Apr 2017 22:02
  • By misael_l
I have more time now and will try to restore this machine as much as possible. First on the list is fixing the brakes. I appreciate all the help so far!
Is there a service manual for this particular forklift or one that has similar parts (like the lift and transmission)?
Once I get working brakes I want to look at the transmission. Also I believe the engine is leaking and allowing a lot of the fuel to escape.
  • Posted 25 Sep 2016 04:14
  • By briankb
I didn't realize the specific demographic of this forum. Thanks for letting me know.
  • Posted 20 Feb 2016 12:45
  • By briankb
What is it that you are trying to move in your backyard with the forklift? You're asking questions to people that repair and maintain forklifts to keep them at factory safety specs about using a forklift with no counterweight and brakes. I think you may be on your own.
  • Posted 20 Feb 2016 12:11
I spoke to a heavy machine mechanic by phone today, about a possible trade but that didn't work out. As the main issue is the weight of this machine against the sand. He suggested a possible fix is to remove the counterweights. I've looked and it appears the counterweight on this machine is the back, almost all of it.
Questions - How much does that counterweight weigh? And can the machine operate, at a reduce capacity, without the counterweight on the back?
  • Posted 20 Feb 2016 07:33
  • By briankb
I know, now from practical experience and also discussing it with a local heavy machine guy. I just didn't realize how loose my soil in the back yard was. He is suggesting a 4WD lift and I'm also considering a tractor with bucket/lift on front.
Either way I need to sell or trade this one I have now. I would appreciate any suggestion on what it's value is in it's current state. I had the starter rebuilt, runs good, no brakes, and I replaced the old LPG tank with a new aluminum one last week.
  • Posted 17 Feb 2016 07:06
  • By briankb
If this truck gets stuck then a newer truck the same capacity will be worse because they are equipped with smaller tires than your present machine.
  • Posted 17 Feb 2016 06:58
  • By duodeluxe
  • United States
duodeluxe
My backyard is too sandy to use this particular machine. I need to trade or sell it.
What is its value as it sits with the non-functional brakes?
  • Posted 17 Feb 2016 04:06
  • By briankb
No it sounds like a transmission issue. You would have to perform transmission pressure checks to verify it.
  • Posted 14 Feb 2016 01:38
  • By duodeluxe
  • United States
duodeluxe
Terberg RT223
Big Joe PDR30-154
USD7,500
Lee Rushton Lee Rushton
Linde Material Handling
