Fault code 9024
Fault code 9024 ? Yale Forklift - will not start any ideas ?
  • Posted 24 Jan 2016 19:13
  • Modified 24 Jan 2016 19:37 by poster
  • By jacko_j
  • joined 24 Jan'16 - 4 messages
  • moray, United Kingdom
Hello was wondering if you figured this problem out ? Have the same problem on our truck and need some answers.. thanks
  • Posted 16 Nov 2022 12:37
  • By Gene_HANBY
  • joined 16 Nov'22 - 1 message
  • West Virginia, United States
Brewski - many thanks, I've not fixed it, but at least I know what to look for, cheers
  • Posted 26 Jan 2016 03:28
  • By jacko_j
9024 is a short circuit. Check your hydraulic motor cables and motor for short.
  • Posted 26 Jan 2016 00:50
  • By BREWSKI
Fault code 9024 on Electric Yale Forkilft Model ERP30VL - S/No. A976B03184K - can anyone help !!
  • Posted 25 Jan 2016 20:05
  • By jacko_j
thanks for the message back :- Model ERP30VL S/No. A976B03184K
When you put the key in everything looks normal until you sit in the seat, you get the 'spanner' along with 9024 code. With a symbol which the manual suggests 'check hydraulics'. but nothing operates or allows you to more the forklift. Hydraulics seem fine, removed and checked filter, all good. Only the lights work - stumped as to what the code 9024 means
  • Posted 25 Jan 2016 00:33
  • By jacko_j
complete model and serial number please.
The model (ERP30) should be a battery motive forklift, when you say "start" please further describe.
  • Posted 25 Jan 2016 00:22
  • Modified 25 Jan 2016 00:23 by poster
