2007 hyster b60z ac electric pallet jack
i have a hyster b60z ac jack , runs fine lifts and operates
after a while it will throw a code29456 , i found out it means error in control module speed / direction sensor, anybody tell me how to access the computer by useing the buttons on the handle, and what it would take to fix this issue ? the controller says iskra on it
thanks
  • Posted 28 Dec 2015 15:35
  • Modified 31 Dec 2015 04:42 by poster
  • By jtt81968
  • joined 28 Dec'15 - 8 messages
  • New Jersey, United States
thank you , i will try that
  • Posted 1 Jan 2016 02:16
  • By jtt81968
I think you need to access the forward/reverse control potentiometer
This should get you to were you need to be.
1. Turn on the truck with the tiller in the rest position and with both the lift and lower buttons on the left hand side held down together, release the buttons after 5 seconds. The tester screen is displayed on the DDI
The screen shows the control inputs COMBI INPUTS, press the left hand lower button for 5 seconds and the tiller head calibration screen will be displayed on the DDI, SCREEN (Tiller Analoge input.
2. Moving the butterfly forward slowly to full throttle the curser moves left on the input screen, then return to the centre, move the butterfly slowly in reverse to end of stroke and return to centre, do this three times.
3. Press the left lift and lower buttons at the sme time to save the calibration and release after 5 seconds. Switch of the switch. Switch on again and see if this has cured your problem, if it dose not sort your problem you may need a new tiller board.
Regards Nero
  • Posted 1 Jan 2016 02:07
  • By NER045
thank you, i would really appreciate it
  • Posted 31 Dec 2015 00:27
  • By jtt81968
Hi it's a long time since I've done this I will have to look the info out.
If I can find the info I will come back to you.
Regards Nero
  • Posted 30 Dec 2015 21:06
  • By NER045
Unicarriers FHGE35T5S
JLG G12-55A
