light on dash is on
looking for info is this a issue? can it be reset? Thanks
  • Posted 25 Nov 2015 06:18
  • By cownd
  • Arizona, United States
orchidlane29@gmail.com
thanks for the reply edward t, the customer said they repaired a broken wire disconnected ansd re-connected the battery and now all is working fine. Never got our eyes on the unit all the info was relayed over the phone from the customer dont know which wire but will try to find out. thanks again
  • Posted 26 Nov 2015 01:21
  • By cownd
in the hour meter does it show the hours? or does it show a code?, as a general rule, failures that are repaired the light goes out automagically. it may very well still have the failure. can you further describe the light?
  • Posted 25 Nov 2015 23:21
  • Modified 25 Nov 2015 23:22 by poster
AT18C01329
customer says the light is a steady flash
  • Posted 25 Nov 2015 06:41
  • By cownd
You will need to provide a complete serial number.
Depending on what the actual fault is you may have to have a Cat dealer come in and reset.
  • Posted 25 Nov 2015 06:33
  • By Partsguy5
Terberg YT223
Unicarriers FD80-2
