Can't find the crank sensor!
Hey all, my company has a 2004 Nissan 50 MPL02A25LV and it won't start, and it doesn't get any spark. After asking around, we determined that it is most likely the crank sensor. I have the new one, but I can't find where it goes! Any insight?
Thanks!
  • Posted 22 Nov 2015 05:19
  • Modified 22 Nov 2015 05:19 by poster
  • By Heyitsjeff
  • joined 22 Nov'15 - 1 message
I think the LV is made for/in USA.
I would check dash code first?
no code? change the relays in the relay box (swap all with known good). Maybe key switch or wires to key switch if no code.
  • Posted 3 Dec 2015 22:48
  • Modified 4 Dec 2015 03:11 by poster
Is this engine fuel injected? If so the crank sensor is located at the front of the engine between the crank pulley and the water pump. There are 2 sensors here, the one pointing down is the crank and the one pointing in is the cam. This only applies to the injected engines. As a thought, the model designation for an injected engine is usually MPL02A25DV or JV. Not sure what the L means. Also a faulty sensor will show an error code on the dash. Cheers!
  • Posted 3 Dec 2015 21:19
  • By QueenslandSteve
  • joined 29 Sep'08 - 10 messages
  • Queensland, Australia
JLG G12-55A
Enforcer FD50T-MMA
Esie Cortez Esie Cortez
