Linde E20PL error code L225-L810 & L347.
Hello,
I'm having a trouble with the Linde E20Pl Model H2X386B04000.
The display show the error code L225-L810 & L347.
The forklift whell is catching and i can drive forward and reerse.
Could you guys send me the manual or error code list please?
Regards.
Rodrigo.
  • Posted 20 Nov 2015 15:57
  • By rodrigo_s
  • joined 20 Nov'15 - 2 messages
  • Rio de janeiro, Brazil
It turned out that there is a breakdown on the winding of the hydraulic motor.
  • Posted 13 Apr 2022 04:35
  • By tomason2
  • joined 5 Apr'15 - 53 messages
  • Poland
serwiswojnarowski@gmail.com
first make sure that your brake pressure is good check the two lower solenoid valves in the valve block whether there is any dirt between themAt the
moment of driving or stopping, your brake is operated if your pressure is not right you get an alarm
  • Posted 20 Feb 2022 20:08
  • Modified 20 Feb 2022 20:10 by poster
  • By michel_v
  • noord holland, Netherlands
225 Pump motor does not run up to speed although a control signal is present
347 Pressure in brake pressure accumulator <25 bar
800-863 Fault in the Lifting power unit
  • Posted 18 Feb 2022 18:04
  • By michel_v
I have exactly the same problem. LINDE E16 - 386-01.
Such errors pop up on the display. First L810, then L225 and L347. Replacing the pump motor rotation sensor did not help. There are moments when the trolley works without any problems, and the longer I use the trolley, the more often errors appear.
Do you have a solution to this problem?
  • Posted 17 Feb 2022 03:13
  • By tomason2
  • Poland
hi Rodrigo
ur email then i can send you something
  • Posted 24 Dec 2015 23:13
  • By lsj_f
  • joined 28 Jan'15 - 16 messages
  • No, Indonesia
Hello gc_d!
Thanks a lot for your help.
I have checked the sensor and I didn't find any problems.
The fault is intermittently and just happen when I put the joystick on "zero" position. I suppose the pump it's not keeping the right pressure on the system. Some times happen when I use the traction also. Is the letter L in the begin of the code a Lift fault? If yes why is happen when I'm traveling?
I apriciate if you can help me!
Best Regards,
Rodrigo.
  • Posted 26 Nov 2015 10:51
  • By rodrigo_s
L810 is speed sensor error pump , check pump and sensors or replace sensor
  • Posted 26 Nov 2015 06:37
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Nagano NUZ090D
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
October 15-16, 2025 - Las Vegas, United States
November 13-14, 2025 - Berlin, Germany
