High Pitched Beeping
Gents,
Hopefully you guys can help me out once again.
We have a high pitched buzz/beep when the ignition is switched off. the truck is in neutral and the handbrake is applied. The only way i can stop this noise is to remove teh display or battery supply
  • Posted 7 Nov 2015 02:50
  • By Andre
  • joined 5 Jan'15 - 11 messages
  • preston, United Kingdom
Gents, i will have anotehr look and get back to you both
Thanks
  • Posted 5 Dec 2015 03:15
  • By Andre
does it have a swing out LPG tank bracket?
  • Posted 4 Dec 2015 03:28
One possible cause is the handbrake switch is broken, so even though the brake is applied the buzzer goes off. The switch should have a metal actuator arm on top, this is what breaks off.
  • Posted 3 Dec 2015 21:33
  • By QueenslandSteve
  • joined 29 Sep'08 - 10 messages
  • Queensland, Australia
Enforcer FLBAXT25
Taylor T650L
Esie Cortez Esie Cortez
