P0087 error
H50D-02- P0087 error code - low rail pressure
forklift behavior--75% speed is ok but full speed was low pressure and create error P0087
Running hrs: 33hrs only
checked all fuel line for leak...ok
Bleed fuel line...ok
checked filter and strainer.... no dirt
feed pump....ok
Any experience like this for new Machine...Thanks
  • Posted 19 Oct 2015 04:34
  • By wilson_b
  • joined 19 Oct'15 - 18 messages
  • RIYADH, Saudi Arabia
I'm TECHNICIAN to save time,Let's just assume I'm always right
Had this happen and unit goes into limp mode. Unit went to shop and fuel pump and fuel rails had to be replaced. If this is a common rail engine ,this may be your problem. Linde had shop replace fuel lines. That did not work. Linde rep came down and fuel pump was diagnosed.Pump falls apart and fuel lines have to also be replaced. Metal shavings in fuel lines.
  • Posted 19 Mar 2017 00:12
  • By edward_m
  • joined 11 May'15 - 111 messages
Solved....the fuel feeding pump was dirt and cleaned
  • Posted 19 Aug 2016 05:43
  • By wilson_b
I had this problem with a warranty truck.
Linde had me replace sight glass & plastic tees in fuel lines with metal fittings suspecting air leaks in system.
finally we replaced fuel rail pressure sensor to correct issue.
  • Posted 1 Nov 2015 07:51
  • By timbob
  • joined 6 Oct'12 - 7 messages
Maxlion FD25
Terberg YT222
