Schematic
Unit will not drive and wondering if anybody has schematics for this old beast ( EV100 system). Ser# 1A205916
  • Posted 22 Sep 2015 21:56
  • By BrewCrew
We`re here for a good time
thanks for the info, voltages are as you stated
  • Posted 12 Oct 2015 00:01
  • By BrewCrew
TB2 is battery volts when both seat switch and accel are made. TB5 and TB6 should only be battery volts when either forward( TB5) or reverse( TB6) not all the time like you have. TB1 will be about 3.5 volts going to zero volts as you press on accelerator
  • Posted 1 Oct 2015 08:36
  • By popeye
The hand set indicate code -01 seat switch but not quite that straight forward ,the switch test good showing batt voltage at TB3 and TB4. I understand that T5 is forward and T6 is reverse so should I have full battery voltage at these contantly until the ground circuit is completed by the controller ?. Accel pot is good and registers at the card and all directional micro switches test good.
Nether forward or rev contacts pull in but all other functions work fine, any pointers.
  • Posted 30 Sep 2015 23:43
  • By BrewCrew
Aichi SR18A
Aichi SR10C1SM
