Dead ignition switch
My H50XM forklift was operating just fine and I shut it off. When I went to start it an hour later the switch was completely dead as were all the gauges and lights. The battery is good and the terminals appear to be tight and solid. My question is, where do I start looking? Is there a fuse box or panel some where?
  • Posted 16 Sep 2015 08:39
  • By jdw72
  • joined 16 Sep'15 - 1 message
  • Wisconsin, United States
I cleaned the sludge and grease from the engine bay and off the transmission with a rag as to not spray water into the electrical system. I found that this actually brought out all the problems with the wire harness because it now had clean metal on which to ground out (the trans). THE IGNITION WENT DEAD TWICE. it had blown the main 30A fuse. since then I have rewired most of the H50xm Wire harness.
  • Posted 24 Nov 2016 00:41
  • By Vantech
  • joined 23 Nov'16 - 5 messages
The fuse box is on the left side of the truck under the dash. The main power fuse is 30 amps. Do you have work lights on the truck and is so were they on when you were using the truck??.
  • Posted 18 Sep 2015 06:22
  • By lifter01
  • joined 4 Jul'09 - 462 messages
Kai von Berg Kai von Berg
