Exec Error Shut down
SP3450H
Will intermttently shut down from full speed travel. Dispay and all functions disabled. Display mod flash a 2-58, Steer module 2-58 and the Traction module 316. (No codes logged in fault history)
This only happens about 2 to 3 times for every 6 to 8 hours of run time. Truck is clean. Batteries that cycle through this truck are in great shape and clean. Connections/plugs at dist board and modules are good... Ayone have this issue that can throw me a hint/clue??? Thanks
  • Posted 27 Aug 2015 06:40
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
The 258 codes being flashed by the display and steering moduals are for communication fails (CAN) between them. You will probably want to check control cords through the mast first. Other thing to check would be battery. If battery voltage drops to low one or both of them could flake out for an instant and loose communication
  • Posted 27 Aug 2015 09:21
  • By popeye
Aichi RX07B
Crown RR5225-30TT321
Aichi RX07B
Aichi RX07B
