No Start
I have a Toyota 7FGU15 that had a bad distributor. We replaced the distributor, but now have a no start condition. Found that the fuel lock-out solenoid is not energizing, no battery volts. Traced it to the relay. The coil to the relay is not getting a negative. The schematic appears to show it coming from the e/g rev switch.
Coukd this be a bad switch, or could it be related to the new distributor?
  • Posted 6 Aug 2015 07:15
  • By d_g_j_h
  • joined 6 Aug'15 - 2 messages
  • Belgium, -
Wires from the distributor look ok. Could the e/g reverse switch be the issue?
  • Posted 8 Aug 2015 05:53
  • By d_g_j_h
  • Belgium, -
Hello, check the wires going to the distributor. they break up inside the harness. or along the top of the engine at the hold down clips.( Wears through). Very common problem.
  • Posted 6 Aug 2015 22:43
  • By Prentice
Taylor TXB180S
Crown RD572513TT6860R
Taylor TXB180S
