Got Problem fault code 47 jumping in and out of drive twice and cuts out any ideals
hi tufty
i am also facing same issue, error 47 and 53 in flexi g3 GE.did you rectify this issues if yes ,please share your solution it will help me a lot ,
thank you
Hi Peter checked contactors got fault 53 and 47 truck is a GE not a zapi flexi are looking at it for me thanks for the input
Hi,
Have you checked that the contactor next to the 2 drive contactoris not welded in.
Pete
Thanks I have replaced both contractors still got fault
Hi,
error AL47 means main contractor closed, check all contractors are operating correctly.
Pete
Hi Pete I believe it's DC ZAPi any ideas. I have replaced direction contactors and direction joy stick
Hi,
Is it DC or AC drive system, plus what system is fitted Zapi or GE.
Pete
