F30 not moving
Hi.
I have a problem with cat f30.
It will go only forward if the steering is fully left, or only reverse when the steering is fully right.
So far some times it was working normally after turning the wheel fully left or right, but now it wont any more.
Any ideas?
Thank you.
Yiannis.
  • Posted 13 Jul 2015 18:03
  • By yiannis_c
  • joined 17 Jun'15 - 6 messages
  • samos, Greece
We have a similar problem. Ours will just stop and if you shut it off and go away it will start working again. Hydraulics work but will not move. Frustrating as Cat dealer doesn't seem to have procedure to diagnose problem. Manuals have been lost. Have done a lot of work to it lately so that it would be reliable. Have seen where it could be accelerator controller but any suggestions would be helpful.
  • Posted 13 May 2016 00:42
  • By Carrotman
  • joined 13 May'16 - 1 message
  • Alberta, Canada
Please let me know If you found the problem, I have the same situation except I have to turn wheel all the way right to go forward and all the way left to back
  • Posted 6 Apr 2016 01:35
  • By jpsweedfeed
  • joined 6 Apr'16 - 1 message
  • Minnesota, United States
Thanks.
I will try to reach the sensor and check/clean connections, but there is not schematic.
Is there any chance I could get it
Thank you very much for your help.
Yiannis.
  • Posted 13 Jul 2015 20:49
  • By yiannis_c
  • samos, Greece
if you have or had travel when turning the steering full left or right but not anywhere in the center that sounds like a problem with the sensor board that is mounted on top of the steering axle underneath the control panel.
the 2nd thing that comes to mind would be the directional contactors or the logic card , possibly some connection issues there but if the motors were turning in fwd and reverse when turned left or right then that leads me to think something wrong with the steering position sensor board.
Try running the onboard diagnostic and see if it will pass the steering angle sensor test (test 5).
Hopefully the schematic is still underneath the hood, if so it has all the instructions on how to do the onboard diagnostics.
make sure you remove the drive fuse before the test, it will tell you to if you dont ;o)
  • Posted 13 Jul 2015 20:21
  • Modified 13 Jul 2015 20:26 by poster
Esie Cortez Esie Cortez
