no Hyds
This unit has no hyds? the contractor does not close after start up? i have 10 volts at contractor coil, could this be the transistors or logic card or both thanks.
  • Posted 2 Jul 2015 03:40
  • By Robrauch1971
  • joined 2 Jul'15 - 1 message
rob rauch
Make sure you have full battery charge, and that the hydro control valve spool switches are adjusted as well. Being that you have a possibilty of several configuration of panels in the this unit, be a crap shoot on how to explain or troubleshoot as each panel are similar but different. Could be simple as in pump cut due to a low battery, spool switches, fuse, corrosion or expensive like a main print card.
  • Posted 13 Aug 2015 23:01
  • By RCAV8TOR
  • Alabama, United States
Esie Cortez Esie Cortez
Combilift Ltd
