Front wheels are locked
It feels like the front brakes are Jammed , or the differential is stuck. The motor runs but when you push the throttle down it doesn't move and stalls out. I've heard people on here talking about electric solonoid but I don't seem to see any on my model. It has a Detroit engine running on LP. Any ideas of where to start would be much appreciated.
  • Posted 28 May 2015 11:22
  • By Kman34
  • joined 28 May'15 - 2 messages
  • Quebec, Canada
I can't afford a vacation so I'm gonna drink till I don't know where I am. 😝
Thank you sir , now I have a place to start. I'll post my findings
  • Posted 29 May 2015 02:25
  • By Kman34
  • Quebec, Canada
first i would jack the front wheels off the floor (blocks under the mast with full tilt forward usually works)
then make sure the brakes are not applied (deadjust them if needed)
also make sure the parking brake is not applied (deadjust this also if needed)
if problem still exists then you have deeper issues as you suspect in the differential or transmission.
one other thought came to mind, you should pull the wheels and make sure all the brake hardware is intact, if any part comes loose and jams between the drum and any fixed part in the brake assembly it can lock up like this.
  • Posted 28 May 2015 22:10
Aichi RX07B
Maxlion FD25
