Hydraulic Issue
Hi I have a problem with an H25D-03 1998 regarding the operating hydraulic valves. We've just bought the lifter and found disconnected lines coming out from the oil cooler. we also have missing engine fan blades and the hydraulic lines for the side shift. Maybe someone can help me solve this problem? Or know from where I can get a workshop manual.
Thanks
  • Posted 4 Apr 2015 01:31
  • By sam287
  • joined 4 Apr'15 - 1 message
  • Malta, Malta
Sam
Contact a Linde dealer and give model and serial number and they can direct you. Also include the mast number which is on the left side rail. its a rectangle stamped tag. mast number is needed for hose length.lines coming out of the radiator, line on the left of radiator goes to the hyd tank. line on the right goes from radiator to the fangear motor, then to the hyd tank I BELIEVE. both are called formed hoses. also have two hoses coming off of oil filter.Hope this helps
  • Posted 15 May 2015 11:28
  • By edward_m
  • joined 11 May'15 - 111 messages
UN Forklift FBR25NQC3
UN Forklift FGL35T
Muncie, IN, United States
Kai von Berg Kai von Berg
