EKS308 code E2130
Unit giving code E2130 and has no travel or lift. If the pallet clamp is open and the display shows its closed remove the floor cushion to access the inspection panels. Remove panels and check electrical connection on clamp sensor and plug XS104 on controller.
  • Posted 6 Mar 2015 03:59
  • By tomas_s
  • joined 24 Sep'10 - 60 messages
  • Bahamas, Bahamas
Check the hydraulic setpoint, this error relates to the clamp open limit position not being reached within a specified time. Check if the movement is slower than normal
  • Posted 11 Mar 2015 05:51
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
F. Uchiyama
